2008 XL1200n frame same as 2011 XL1200x ?
  • oldmate
    oldmate
    I think i have a bent 2011 XL1200x frame (48) and might need to replace it. Have the option of buying a 2008 XL 1200n (nightster) frame. What is different about the two frames? Anything or will this work out for me?
    Regards, Oldmate.
  • one_oak
    one_oak
    how did you bend it?
  • oldmate
    oldmate
    With an oxy torch, trying to rake it out........
    No it had a head on. fork tubes are foooked and have a good lead on a cheap frame rather than have to straighten.
    Anyway, is it the same frame?
  • Oldman
    Oldman
    No oldmate they are not the same frames. 2011 48 has frame  #49376-11
