Online: Stuart
Tuner help and advice
  • DRAIN
    DRAIN
    just ordered big radius pipes and a se heavy breather for my 1200c
    Been reading a bit of stuff on tuners etc.
    Wondering what people on here use etc.
    What's good for price and what is overpriced.
    Any advice would be great.
  • terroristone
    terroristone
    In my experiance you cannot go past factory tuners, ie Screaming eagle for harley, harley have a much much larger budget to play with and anybody with 10cents in their pocket who thinks they can make something better is kidding themselves in my book. but at the end of the day i'd say you have to find a person who can tune first and ask what they prefer to use!
    Andrew
  • DRAIN
    DRAIN
    but isnt there some that are pretty much plug in and there is settings for different pipes and breathers etc? Like from what i read that's what the Vance and hines one works with.
  • terroristone
    terroristone
    yes there is, but not all engines are the same! so their "tubes" will always be way on the "safe" side (too rich and not enough timming)...tune it right and tune it once!
    Andrew
  • BAKES
    BAKES
    TTS is an excelent choice of tuner, no plug and play, it reprograms your ecm and you can tune it yourself.
  • Grand Tourer
    Grand Tourer
    Can't say too much about tuners, but I installed the same pipes and breather as yourself onto the cooks nightster. We used a power commander v, after a dyno tune the thing flies, bit of popping on decel but not overly bad.
  • DRAIN
    DRAIN
    still looking into things
    So undecided. There's way to many options with this and i dont know enough about it, as ive never had to do this kinda thing before
    Price is a factor as well as how easy it is to set up etc.
  • slapster
    slapster
    I just bought the SEPST (32109-08B) off ebay the other day for $365 delivered. I'm no tech but I thought the price was reasonable & the super tuner seems to be a popular choice.
  • brucecul
    brucecul
    i have a dobeck tuner on my bike for the last 4 years . works great and hasn't let me down , easy to fit and use
  • brucecul
    brucecul
    that is piss cheap good on you they work well
  • pistol pete
    pistol pete
    i run a pcIII had it dynoed been running on the bike for two years goes like a shower of shit never had a problem
