Deuce rear wheel
  • dyna gliding
    dyna gliding
    i have a deuce rear wheel and i was wondering if anybody knows somebody in Sth Adelaide that can dril out the center to fit a 1in axle and take of the ribs off from around the edge and then the price of getting it chromed
  • bike bling
    bike bling
    hey buddy i fitted a duece rear wheel to my 06 dyna when i had it you will need the bearrings and spacer that goes between them as well to suit the 1" axel i had mine chromed and left the fins as i liked the look you will alos need to machine the rotor mounting hub as it will be slightly bigger when chromed and teh rotor wont fit i found this out the hard way after the chroming was done so i machined the rotor instead i have a mate in adelaide that could do the machine work for you if you still need it done let me know and ill pass his details i\on
    jezza'
    0400125545 / 0887255245
    SE BIKE BLING
    MT GAMBIER SA
