Spike air cleaner remap yes or no?
  • Spero
    Spero
    I've got a 2011 FXST Softail Standard & I'm piecing together a D & M spear air cleaner, Vance & Hines 2 into 2 big radius pipes & a Screamin Eagle race tuner kit. My question is that i can't afford to get all the items at once so i was looking at buying the air cleaner & installing it first, then the pipes & remap at the same time. If i install the air cleaner without a remap will i damage my motor due to it running to lean etc? If the answer is yes i'll hold off & install all the items together when i can afford them.
    Any advice is greatly appreciate! Spero...
  • the_mongrel
    the_mongrel
    Yes is the short answer. I would not open your air without a remap.   Same with pipes.  I would not run too long after swapping pipes without a remap.
  • Spero
    Spero
    Cheers for the advice! I had a feeling that was the case but I wasn't a 100% sure..
