Installing chrome ignition coil cover on a dyna
  • Pastrypete
    Pastrypete
     Hey guys just picked up a chrome ignition coil cover for my dyna and was wondering how hard they are to install ...looks a bit technical to me ...anyone got any links to how its done Cheers Pete
  • Pastrypete
    Pastrypete
    Hmmm...and void warranty when I fuck it up ...maybe not ...sometimes a man's gotta know his limitations
  • TheBoss
    TheBoss
    Did you get the instructions? Shouldn't be that difficult.
    Remove your petro tank, undo the wires....mark them if you need too....undo the mount....add cover.....and then put it back together. Clean it and then post up a picture for bragging rights.
  • Pastrypete
    Pastrypete
     Good point might have to take that on board TB
  • Pastrypete
    Pastrypete
     Blouse removed Pearcy ..it was too easy its the instructions that confuse you refering to check workshop manual etc...just pulled leads out undid two bolts holding on coil and installed chrome cover ...job done
