Hot Idle with MT8
  • Fr3d
    Fr3d
    G'day and I need some help please.  I loaded my first MT8 map (DTW205-03) with cam tune and done four sessions with the Vtune.  The bike runs like a cut snake, never been this good.  08Road King - 103, 211's, 2 into 1's, hi flow air and head clean up.  My only problem is it runs very hot on idle, around the 250C mark and goes into temperature control which is a problem I never had with the MT7's.  I have the IVO set at 2 which is my take on reading the graph and IVC set at 3.  I run CLB at 645 and will be changing the idle AFR cells at the 30 - 40 MAP to 13.5 to see if this helps.  Any comments on what else I can do to bring the the temp down would be most welcome.  Also would an IVO thats too early have any bearing on this?  Thanks Fred
  • Fr3d
    Fr3d
    ok will try both, thanks
  • BAKES
    BAKES
    Did that solve the problem
  • Fr3d
    Fr3d
    Increasing the CLB on its own did not stop it from running hot at idle but did slow it down. From a cold start with an ambient of around 15C it got to 175C before I shut it off. Will try with the AFR next.
  • Steve Cole
    Steve Cole
    Also make sure you closed throttle timing is set. You should be getting teh same temperatures with either a MT7 or MT8 calibration if tuned to the same values.
