Online: Stuart, Hilly
death wobble
  • stumbly1
    stumbly1
    wonder if it is only pre '08 models? Haven't had any issues with mine - yet....
    Interesting to note HD saying adding accessories after purchase can make the wobble worse yet have a catalogue full of bits for FLH's
  • ductor
    ductor
    You have to fit the bolt on wobble cop.
  • Moose
    Moose
    Ahhhh yeah. Older model electraglides are famous for this. I was the proud owner of a 96 ultra, and I can tell you from expirience that its a  problem that is not resolveable with these bikes. You push them hard in the corners and it will reach a point where it wobbles. True track and other aftermarket devices can minimise it, but there is only one way to get rid of it. Trade it in on a 2011 model. They have a revised frame thats less prone to this unerving thing. Thats how I solved it after 6 years of throwing money at it .
  • Aunty X
    Aunty X
    I pray it doesn't happen to me..or anyone for that matter. No problems with it so far.
  • beagle
    beagle
    The swing arm is mounted to the motor assembly, which is rubber mounted to the frame. In some conditions the flex can get out of control, but you have to be pushing it. Upping the rear shock air pressure can alleviate some of the weave, as on any bike, but there goes the comfort factor. If the engine mounts are a bit loose, not aligned correctly or worn, it can make for interesting handling at speed, but most don't buy a HD to go fast, we buy them to leisurely cruise on country roads and smell the road kill early in the morning....aah!!  clears the fucken nostrils.... You may remember the Qld police had an issue with the ST Hondas weaving at high speed.  From memory, this was caused by the airflow over the rear panniers causing the problems.   Maybe a different cause, same result.....
  • TheBoss
    TheBoss
    I've experienced the wobble effect at turns while traveling at higher speed but nothing like what was displayed on TV! It doesn't happen often.....Air-shocks and the right pressure can prevent that a bit too!
  • Moose
    Moose
    Have to admit the one on the video does seem a bit extreme. I used to push mine hard,and not get the wobble that bad. In my younger days had a speedway bike I used to play with . A little sideways is fine with me, so I did not really mine the old girl getting outa shape now and then. The 2011 mod has not done it at all yet
  • groover
    groover
    I fitted a Glide-Pro Stabilizing system to my 2008 Roadking.
    Was on the verge of selling my bike due to the pathetic handling around the windies.
    Fitted the S/Steel rear fork shaft and urethane mounts with a urethane front engine mount and the difference was truely unbelievable.
    http://www.glide-pro.com/
    Videos on site to show you have to install it also.
    ALso check your front steering head bearings for correct adjustment.
  • groover
    groover
  • grim
    grim
    fitted the glide pro as well---hard to beat--cheers Grim
  • grim
    grim
  • grim
    grim
  • grim
    grim
    fuck dont know what happened then--cheers Grim
  • shaggz
    shaggz
    you must be ecstatic with it grim to post so many times
