Online: speedzter
Belt tension
  • eyeball
    eyeball
    Have just changed the rear tyre on my wide glide, is there any easy way to tell how much tension on the
    belt is needed? I checked it against the notches on the lower belt guard before removing the wheel but now the belt sits a bee's dick lower on
    that guage.
    Any tips, thoughts etc would be appreciated.
  • als1200
    als1200
    Waiting for the reply on this one. Just changed my sporty too.
  • rider
    rider
    with bike on jiffy stand, 1/4 to 5/16 inch (between sprockets, as viewed through the viewing window) with 10 lb force from underside of belt.
    with bike upright and rear wheel off ground, 5/16 to 3/8 inch
    (Or a quickie, twist the belt with ya pinkies and if ya can get it to twist more than 45 degrees it's too loose.)
  • Magilla
    Magilla
    First part of the vid talks about belt adjustment. 5/16 - 3/8 is 7 - 10mm. Use his finger method. Do it while the bike is on its stand. Ensure the wheel is adjusted equally both sides. He goes into that as well.
    Tip: Always use Google!
  • DynaRider
    DynaRider
    Hilarious.
    Lock up your lawnmowers.
  • DaveP
    DaveP
    Hang on, i will just set my finger knuckle to 10 pound. Ok, lets set the belt tension, click in the knuckle, yep thats it, must be a loony tunes clip
