Online: Hilly, Wanderer57
SE 103" SOUND WITH SE SLIPONS
  • beetlebug
    beetlebug
    Can any one tell me what a SE103" motor sounds like with SE slipons,  at the moment I have AB racing LSR 2 in 1 and it is too bloody loud  Cheers
  • Noodle
    Noodle
    Nope ... I can't but was just thinking. It would be awesome to have a 'thread' for ... 'Crank up your bike' where we upload a sound track or well recorded video of the sound of different exhaust systems... with the multitude of systems available ...
    Wish I could hear it.. brummm brummm
  • Noodle
    Noodle
    .... I'm running the Vance & Hines 2:1, I find them good as far as 'noise output' is concerned.. very controllable, loudish when under heavy throttle .. but 'noticeable' under general riding... while I often listen and appreciate the 'note' of a 2:2. The blend of decel noise through a 2:1 balanced pipe is appealing too..
    Put some ear plugs in.. that'll make em quiete...
  • beetlebug
    beetlebug
    thanks for that Noodle,  it does sound good, but havent got enough earplugs for all the neighbours. Will try thr SE slip ons (with the loss of some HP) but gain some preace Cheers
  • Noodle
    Noodle
     .. thanks 'beetlebug' hope you get a resolution mate... but good to have a  on the way...
  • wa_tony
    wa_tony
    Hey, bettlebug, what you talking about a "loss of some HP". I fitted a SE heavy breather, SE slip ons (which sound terrific under acceleration, but don't attract the cops when idling at the traffic lights) and the pro tuner and ended up with 15% MORE power.
  • beetlebug
    beetlebug
    WA TONY,     I have  se 103" stage 4 kit mate, and I will definitely lose about 10-12hp after this system goes on but Im glad to hear that it sounds pretty good still.  Before this change my hp was around 105hp.   Cheers
  • beetlebug
    beetlebug
  • andij
    andij
    s@s make good slip ons .but there are quiter 2in1 systems you got the noisiest ,thunderhead aint far behind .your stage 4 should be more then 105 hp
  • Hillbilly
    Hillbilly
    Too loud???
  • BURTO
    BURTO
     Ear plugs for the neighbors??
  • Noodle
    Noodle
    Naaaaa... They'll all be deaf in a short time anyway....
  • BURTO
    BURTO
     Fuck em!!.....................actually, when I registered the new bike, turns out the lady at the RTA counter is my neighbor. She asked if the new bike was as loud as the old one?..........."Pretty much" says I..............she says "thats good! I use you as an alarm clock each morning!"
    Burto.
