Quote on bars and cables.
  • Sparra
    Sparra
    Are you supplying the bars and cables?? If you are I would think it's a little excesive...
  • Dan
    Dan
    yep, a little steep....
  • moffycc
    moffycc
    ripoff.
    For a Harley dealer, that's about the figure I've heard before.
    Are the bars internally wired ?
    I'll do it for $750 !!
  • als1200
    als1200
    my neighbour done his bike not long ago. bars cables ect lucky if it cost him $200.00 and only a few hours work. $800 sounds (it is) a rip off. find someone else.
  • Train
    Train
    got quoted $1400 to put 16" apes on my Dyna internally wired from Harley Heaven a while back.
    $250 a few beers and a weekend and it was done. Mate give it a go yourself. Its not that hard
  • FXCowboy
    FXCowboy
    Have a go at it yourself and save the $800. Drilled and internally wired my own mini-apes on the FXSTC just for practice because I want to go higher at some stage, and if you've got the service manual it's no big deal - plus there's plenty of videos out there on Youtube to help with parts of the job if you want to see it done. Check the US HD Forums too, lots of threads with photos to help out. The biggest pain is pulling the the molex connectors apart and reconnecting all the pins once you're finishing running the wires. Just slide the tank back until you can reach them - and once out, pry open the locking plate...all covered in the electrical section of the manual.
    Granted, this time I didn't have to run a new brake or clutch cable like you might be wanting to do, but if you've got a basic set of tools you should be ok. Just give yourself plenty of time so you're not rushing anything. Having done it, it's not a job I'd be paying someone else to do for me now ...
