Iron engine clean
  • PK2
    PK2
    Hi all, had my Iron for almost 2 months now, and I'm absolutely loving it! Got caught in the rain yesterday (great Melbourne weather!) and of course its now filthy! The paintworks no worries, but I was just wondering how people clwean the engine? I find the matt black coating is a bit hard to clean and was after a couple of tips.
    Thanks all!
  • terroristone
    terroristone
    i've been in the rain twice now, and on the ring road where they are doing roadworks so its not only wet its muddy. i just used normal car was soap with a sponge and bucket, hose it all off, and fire up the compressor and blow dry off, or atleast use a shammy.\
    Andrew
  • PK2
    PK2
    Thanks guys, been using water and microfiber cloth which has been ok, but the compressor thing sounds like the go.
  • Shotgunhemi
    Shotgunhemi
    If there is hard crap in between the cooling fins like dried splattered bugs ect, I sometimes use a nylon .30cal rifle brush on a small handle and just carfuly give it a light scrub. Works for me.
  • pistol pete
    pistol pete
    use degreaser then when dry apply s100 engine brightner perfect for the wrinkle black finish can be bought from harley brings ya engine back to brand new and all other matt finishes be it grey or black highly recommend
  • 883n Harley Convert
    883n Harley Convert
    Need to get on top of cleaning my iron @ the moment, got stuck in the rain on Friday night and its filthy!!
    Will check out the HD engine cleaner, cheers
  • FXSTC 09
    FXSTC 09
    For cleaning the blacked out wrinkle finish on the engine my bike i find the 3M brand stainless steel kitchen appliance polish in the aerosole can works really well.
    Its also great for cleaning off the stray bits off chrome polish that get smudged on while polishing the chrome.
  • Mr.Mow
    Mr.Mow
    I ride rain or shine and find the black wrinkle just needs a sponge and normal car wash stuff.. not had any problems keeping it clean?
    wet, sudsy scrub, rinse.. go ride..
