Online: Humbug, GGUser744
Seat Foam
  • FXRfreak
    FXRfreak
    G'day all,
    I need to reshape my seat, and being short of cash I thought I would do it myself to save a bit of money. Can anyone tell me where you get the proper high density foam from?  I dont think clark rubber carry it. I have a hot wire cutter for shaping it, but dont have the foam!
  • FXSTC 09
    FXSTC 09
    I rode endure bikes for many years and used an electric carving knife to help reshape my seats with great success.
  • beagle
    beagle
    You might consider using some EVA or PE foam( around 45kg density) as the base with a high density urethane( around 70kg-90kg) on top for comfort. Both are easy to shape. Glue substrates together and trim. try a professional trimmer for offcuts.
