Online: imoo6170
Loading Harley into Ute
  • Gloved1
    Gloved1
    Hi,
    just after some feedback on suggestions for easy loading/unloading of Softail Deluxe into Holden Ute. I have owned Motorcross bikes and know the deal there, but was thinking the Harley must weigh close to 450kg+ and not sure on tailgates ability to support during the process. Anyone have any thoughts suggestions??.
  • Deadwood
    Deadwood
    Hire a trailer?
  • SoftailSteve
    SoftailSteve
     have a look at  www.bikeloader.com.au
  • BURTO
    BURTO
     Load the same as dirt bike basically, if your lucky it will fit diagonally with tailgate shut........more than likely you'll have to leave the tailgate down with the back wheel sitting partly on it.
    450kg sounds a little heavy..........new ultra glide weighs 413kg in running order.
    If in doubt, get a couple of mates and the 3 of ya jump up and down on the tailgate to test it out!!......unless it's a pile of shit, I can't see it being a prob.
    Burto.
  • Firey
    Firey
    Make sure you don't use those crap tie downs for you Harley!
  • Gloved1
    Gloved1
    Robo61,
    I know it probably goes against the grain, but was thinking of taking bike away on holidays so once in a town can use bike for me and the missus to tour around on. Not hardcore enough yet for the long boring roads of the Territory.
    Firey,
    Will certainly not skimp on the tie downs
    Burto,
    your an idea's man lol. had a best guess at the weight, will do a bit more research.
    Thanks all
    Don't know about the shitbox Holden tailgates, but the Ford utes handle it easy !
    Back into a rise if you can so your not riding uphill, and it's a one man job.
    I made this for my bike
  • shaggz
    shaggz
    I have a bit of angle on my driveway so I drive the ute out and stop with the rear wheels in the gutter, By time I drop the tailgate I only have to lift the front of the bike a few inches. My neighbours are smart enough to not whinge about the road being blocked while I load the bike.
  • Finny
    Finny
    Walka thats Fuckin AWSOME, Ummmm Can u please........ ill pay ya :)
  • Flash1970
    Flash1970
    try LIFTWORX .com .au they have a new USA made loader, not on the web site, but have seen at the shop in Brizzy
  • Flash1970
    Flash1970
