Online: HD17
Rusty pipes - normal??
  • gonzo
    gonzo
    Hi all.
    My 07 RKC has rusty exhausts:
    Does this look normal for 16,000km and two years?? The right pipe (shown) is worse than the left.
    Gonzo
  • toxic
    toxic
    just a thought, but would rust converter do any good, just paint it on then hit it with some rattle can heat paint.
  • gonzo
    gonzo
    Success!!
    Used the Dremel with a wire brush, then some header paint, then the heat gun to cure it.
    Thanks for your help lads.
    Gonzo
  • GREG
    GREG
    Or try doing more than 8k a year, better for them to burn out than fade away.
  • toxic
    toxic
    Nice work Gonzales, worth the effort, much better looking than before.
  • gonzo
    gonzo
    You only like it 'cos it's BLACK.... I know you like black, Toxic.
    Gonzo.
