yeah i run bp 95 for my set up great.
All good until you ride out of the metro area, the choice is seriously deminished....I put in whatever is available and have found little difference in 80000ks from one end of the country to the other...
Bt
I currently run with Shell V Power, but after reading an article in a bike magazine a couple of days ago, stating that quite a few people have had issues with V Power, I have decided to give BP Ultima a go.
I like the 98 octane fuel, I have spoken to a number of mechanics who have recommended the 98 octane fuel. I have been using 98 in all my cars for many years. I have found I have not noticed any difference around town, but out on the highway the fuel consuption is so much better.
I did put some ethanol in my car by accident one day, never again. The car was noticibly underpowered and the fuel consumption was shithouse.
I am not an expert, but when quite a few people have said V Power is not the best, I have got to try something else. From reports I have read, the most brands of fuel come from the same refinery, but with different additives for Shell , the same with BP & Caltex too. That is, Shell get the raw fuel then add their additives, BP adds their stuff to their specifications an so on........
So my next fill up I'm gonna try BP Ultima and see what happens
And all the experts do agree it will depend on how you store your fuel, how often you use it. Petrol has a certain "shelf life" and it will go off. I have had fuel in a container for over 12 months, tried to use it even in the lawn mower, and it was no good. I had to dump it.
i'll run anything in my bikes, 91, 95, 98, any brand, whatever i can get as long as it goes bang, i've felt no difference or benefit in any of the bikes, brands or octanes, it's also worth remembering that in the USA, where our bikes are made, their HIGH octane pump gas is 91
i just run Caltex 98 or BP 98, but the rest of you are free to use what you like. after runing BP 98 for a while and lifting the heads for a look the chamber & piston top sure looked clean to me no carbon build up. this is an 01 Twin Cam 95 inch carb dyna Cv carb. i think the BP 98 seems to be on average pretty good like you might get bad caltex or other brands but BP always seems ok. my bike is also a bit higer comp & i need to use comp releases to start. what you need to remember with fuel the 98 is slower burning the 91 is faster burning, you just need fuel that is on the virge of detonation to make the best power. if you have a low compression motor it would most probably go faster on 91 octain than on 98 octain, but if you have a very high comp motor you need to run a high enough octain fuel or risk damage.
also over lean tune not good if you ride wide open throtle.for long periods, but who does that?
I have been using BP Ultimate for the last few fill ups now (used Shell V Power before) and one thing I have noticed the bike is running cooler. The engine oil temperature is running at 105 c. With Shell V Power it was running at 110 to 115 c. This has been after a 2 hr highway ride.
My mechanic (not HD dealer) recommends 98 . His 1st choice is BP, 2nd choice Caltex. He is not a big fan of Shell, though.
So I'll stay with BP for the time being, and see how it goes!!!
Hi there
BP Ultimate. Runs sweet, little decel pop (althought tuning correctly controls this largely), never had a problem.
