Online: beaglebasher, Kato
Popping on Decal, Help please.......
  • sophtayl
    sophtayl
    Hi Steve,
    you still need to do something with your fuel for decel pop and all open loop operation. The Xieds only work in closed loop ie- cruise mainly. The decel pop is still most likely coming from the slip ons you have ( if you have already eliminated the potential exhaust leaks).
    Kind regards
    Mick
  • Robbo
    Robbo
    Hi Steve,
                      I've got a FXSTC07 with V&H staggered bigshots and a hyper charger pro air cleaner, I was running the V&H fuelpac which helped alot but still popped alittle on decel. Went to a Thunder Max with auto tuner, man what a difference. Now I know one is an add on and the other a whole unit but it made a huge difference, but what Greg is saying is right if the fuel and air are not right then popping will happen.
  • PKSHED
    PKSHED
    Mate, got the same prob with the Fatbob. Love the header pipes so put a set of slip on's on. New K&N filter, and the Nightrider xied's or what ever they are. Cheap and nasty, did'nt solve the decel pop, (engine run a bit cooler) and you pay for what result you get. i.e. get the best and forget the rest, if your gunna hang on to the bike like me. Now I'm  looking for the best, any suggestions out there?
  • Hoodaman
    Hoodaman
    I just today had the SE pro race tuner installed and the new SE AC and im as happy as larry......shitload more grunt just there...too freakin dear me tinks but as u i will be holding on to the RK for a while and my next step is the big bore job so thats what i really needed......depends on how much cash u have to blow....
  • Hoodaman
    Hoodaman
    U will find that MIck is a bloody gentleman...I went and saw him for a chat b4 i decided on what i got and he didnt hesitate to drop everything and talk to me......if thats ur intention i believe Mick will have the answer ur lookin for mate...
  • Hoodaman
    Hoodaman
    OOPS...sorry bout that Mick....Ill blame the Smirnies mate....
  • sophtayl
    sophtayl
    No probs at all Hoody, didnt think it fair on BJ to take his credit ;)
    Mick
  • Peter
    Peter
    I SHOULDA GUESSED
  • PKSHED
    PKSHED
    Scotty, have you heard about or fitted a Terminal Volocity-3 unit?
  • ronster
    ronster
    Steve
    please update when you install the Fuelshot. Would be very interested in the results.
    Picked up a stock 07 Fatty a coupla weeks ago and have ordered Rush 1.75's and a big sukkar. (The missus reckons that is appropriate).
    Now have to decide on fuel management so your results will help with the decision.
    Thanks
    Ronster
  • sophtayl
    sophtayl
    Hi Hogman,
    the exhaust Actuator is located in the tail end of the primary rear exhaust pipe on the standard pipes. Follow the exhaust pipe along and you will see it ( if you havent changed your pipes). You can look at our website for where to find it and how to eliminate it without modifying your bike. Simply plug in an Exhaust actuator eliminator and the flap stays open. No requirement for self tapers, etc.
    Note, the butterfly is closed in most normal riding conditions except Idle and over about 70 kph. I must admit, I struggly to see that this will be giving you the decel pop talked about, as its purpose is to redirect all gases through one muffler box during city type riding to keep noise down. It is infront of the muffler boxes and directs all the gas through the front muffler box.
    Mick
  • Brett
    Brett
    Nothing but praise for the fuelshot,easy to fit ,easy to adjust [Big Joe's sent it ready to go , but no problem even for me to adjust if need be] absoulutly no popping, no friggen around with bloody computers,takes up no room and most importantly my 08 fatbob is running very sweetly indeed ! ps great service from Joe's
  • PKSHED
    PKSHED
    That's great to hear mate, mine is in the mail so mick reakons and will fit to the Fatslut asap. Watch this space.
