Online: speedzter
2012 Mastertune Update Released
  • Steve Cole
    Steve Cole
    We have released a new set of updates that includes tuning for 2012 Touring models only. The other models will follow as we get them finished up but since we had a few other upgrades already in the software we decided to release those along with the 2012 Touring product at this time. One thing we added to Vtune was a new feature for those of you adjusting the EGR. On the screen that shows the modified VE values you can now go to the "Settings" Menu and select "Highlight Low Map". This will change the display so you can see the area the EGR will affect. These values are shown in bold font. I hope this helps some of you figuring out what areas see the most affect from the EGR adjustments. This feature can be turned off or on while viewing the screen.
  • KiwiRob
    KiwiRob
    Plus two
  • KiwiRob
    KiwiRob
    Just downloaded the latest updates. V-Tune histogram has an improved tracker, which helps with those of us with failing eye site when using remote mini screen. Top stuff.
  • KiwiRob
    KiwiRob
    Was using a USB powered Samsung U70 7" monitor, but it was a little bit small to see without having to squint. Worked a treat otherwise.
    Had it mounted by drilling a hole through it's adjustable/swivel stand then used the nut that holds the console in place to secure it. Mounted it low enough to see the speedo.
    Bit akward to turn ignition on & off though. Mounting higher, like on the handle bars, would have been better & safer,
    Working on a way to mount a Lilliput UM-80/C/T 8" touch screen monitor which I purchased via ebay. It's much easier to see & also the touch screen feature should be good so I don't have to take the lap-top out of the carry bag each time I stop @ the end of each V-Tuning session.
