Online: John.R
corrosion in fuse box, electric grease?
  • jim76
    jim76
    Gday, think i may have found my problem on my 08 sportster and its high idle. the fuse box had corrosion in it i cleaned it up over the week end n took it for a short run it seems to have fixed it it was all so loging codes in it for the blinkers i think the corrosion may have been my troubles. does some one make an electric grease that i can put into the termonals of the fuse box to stop the corrosion i was told to spary it with silicone spary but not sure dont want to course a short n have other troubles. have been to a few auto electric places n auto shops but no one has heard of it before does any one no of brand names or part numbers so i can try n get some to put a stop to the corrosion
        thanks  jim76
  • jim76
    jim76
    thanks scotty thats all i got this after noon was dumb looks n one fellow said "nah they dont make stuff like that" i think that was the easy way out for him. will write it down n go get me some tomorrow thanks again
  • Peter
    Peter
    Permatex gasket goo was the only thing that stopped the old Bonny from leaking oil, it never leaked a drop after using that stuff.
  • Thomo_Baca
    Thomo_Baca
    Was told to put vaseline on battery terminals to stop corrosion, that be a goer
