Online: GGUser744, speedzter
no rear brake lights on iron?????
  • 666
    666
     cant  work it out no fuse gone have front brake light anybody got any ideas
    If you have Changed you Bars or Grips, you have Broken the Brake Switch, putting it back together
  • Rocky2010
    Rocky2010
    Sounds like the wire may have broken off from the rear brake light switch, if this is a Sporty.
    Check the wiring, bridge the 2 brake light switch wires together the rear brake light should come on, the switch could be faulty.
  • 666
    666
     yep will check switch today that was my thoughts but i did put new grips on the other day so will check up there as well .
  • 666
    666
     ok found the problem the little nib broken off the front brake switch rang m&w  there quote $75 for the part holy shit for a simple tiny switch part number h71621-08
  • AJ56
    AJ56
    Mate I have seen them on Ebay for 30 bucks in the US. Easy to fit as well.
