Online: Hilly, Crowbar
Nightster X 48
  • sjn25281
    sjn25281
    Does anyone know what is required to put the taller nightster front wheel on a 48? Is it just a wheel change or do the whole forks need to be changed?
  • 883n Harley Convert
    883n Harley Convert
    It would be the entire front end, if you're after one, I'd be keen to do swap! Have a 2010 Iron and am looking to make a few changes, have been investigating 80 spoke wheels for the front and back, however wouldn't mind putting the 48 gear on!
  • sjn25281
    sjn25281
    I would do that for sure, but you'd have to wait until October...
  • TC883
    TC883
    Not wanting to rain on any parades here. The Wollongong Frasers entry into the 48 build off competition run earlier this year put a standard width front wheel from a Nightster on a 48. They did not change the forks, just used different spacers for the front axle (I think?). Looked a bit strange to me, but each to his own....If you rang them and asked for Mitchell, I am sure they could tell you what they did. TC
  • sjn25281
    sjn25281
    TC883, any chance of a pic or a link to that bike?
  • Mr.Mow
    Mr.Mow
    Why wouldn't you buy a nightster and put a 48 peanut tank and single seat on it.. Hey presto! 48 nightster cross.. Sounds a he'll of a lot easier than replacing the front end of a bike..
    48 and nightster are pretty much the same bike otherwise.
