Online: Hilly, Crowbar
Sportster Wiring.
  • ElDubya
    ElDubya
     Hi all,
    Is anyone here good with wiring and live around the sthside of Brisbane? The wiring is a freakin' mess on this bike I bought and I need someone that knows what they are doing to come and sort it out for me. Any takers :)
  • ElDubya
    ElDubya
    No-one huh? Oh well, looks like I'll be paying some random auto elec then, cheers.
  • als1200
    als1200
    not in your area but how bad is it....whats giving you the shits.
  • ElDubya
    ElDubya
    The bloke that owned my bike bike before me has chopped all the wiring to pieces to fit a wideglide tank and dash board to it, and my front indicators don't want to work. They didn't work when I bought it. The neutral, highbeam, oil and indicator lights on the dash don't work either, but I'm not concerned about those. I have got the test light out and tested everything, sometimes the front indicators spring to life, but mostly they are dead. I bit the bullet and bought new switches and wiring to suit so I'll fit those and see how I go. Hopefully it should fix the issue.
  • als1200
    als1200
    Bugger,  do you understand how the wiring works as such.  do a search on this site as you will find some very simple to understand wiring diagrams which might help.  Been down the same track with a jap bike some time ago and i know your frustration.  remember one wire at a time. make sure the joins are done properly, make sure that you have a very good earth (most problems are from that) and dont use quick joining connectors.
  • ElDubya
    ElDubya
    I am normally pretty good with wiring (car stereos, alarms, etc) but looking at the wiring diagram in my bike manual makes my eyes bleed. I ordered new switchblocks and wiring today so I can route them through my new bars then tackle the bloody indicator issues. I originally bought the bike as a "put it in the garage, strip it and rebuild it" option so I was half expecting some issues, looks like my expectations were well founded :)
  • als1200
    als1200
    its all good fun. but like i said earlier do a search for wiring diagrams on the forum and you will find some easy diagrams. get it going quick and come on the run to burrum heads (qld ride section)
