Online: Ronmac
How reliable is a 98 to a 95
  • simmac18
    simmac18
    How reliable is a 98 build compared to a 95.  I have just about settled on a 95 build of Hallam Boyz Stage II Heads, 37B Andrews Cams, I think if I go 95 I will use SE Forged pistons just because I am getting a Harley dealer to put it all together.  I was looking at Wiseco pistons in a VT2765 and had almost settled on them, then I was looking at the sizing after getting feeback here and thought the 98's aren't much bigger.  Do you have to replace the crank, or is the Harley original in my 88 strong enough, and could I still use the 37's or would I need to make the heads able to take a higher lift cam if I went that way, it looks like you get a fair bit more from the 98.
