Online: Humbug, GGUser260
2006 streetbob rear wiring harness???
  • kickinon
    kickinon
    Hi, im looking at fitting up one of those bobbed rear fender kits like the wide glides run, but in the instructions it sais you will have to cut your plug of to feed the wiring out of the condut (if you want to use the existing loom) but im going to fit one of those tail lights that have the turn signals in it as well as the rear brake/tail light, so's to do away with all the stuff on the struts & fender, & dont want to cut anything just lift the whole fender assembly in one shot, fit the new one the same, in one shot with wiring attatched ready to plug in under the seat, So l guess my question is ...Does anyone know the wiring loom part number for rear fender to suit a S/Bob?? & has anyone done this same conversion?? perhaps has some tips before l get started??.......Thanks...
  • Purnong
    Purnong
    The conduit is just glued on under the guard
    No reason you cant remove it and glue it to your new guard provided your plugs are the same as the new light
  • kickinon
    kickinon
    ok, just purchased a new rear wiring harness ,,found the part number on my old one, easy that way dont have to cut anything...
