Online: softfat
Exhaust Question.
  • Robbo
    Robbo
    Could anyone tell me whether I can put the exhaust from a FXDF onto a FXDC with mid mount pegs, ie is there enough clearance for the peg/brake pedal to clear the exhaust and still operate correctly.
  • BURTO
    BURTO
     Should fit Robbo, the Fatbob came out with the option of mids or fowards (in the US only).
    The pipes are low enough to allow a midmount footpeg to fit.
    Burto.
  • FatRob
    FatRob
     On the FXDF there was a different heat shield for the mid mounts and forwards.
    Part numbers are:
    66840-08 for forwards, and
    66841-08 for mids.
    The standard one fitted to the Australian market bikes does not clear mid mounts.
    The mid mount foot rests are common through the Dyna range, there are no different ones for mid mounted Fat Bobs.
    I fitted a system off a Street Bob to my bike when I moved the foot rests.  I wasn't a fan of the original FatBob system anyway.
    FR
