Online: Ronmac
Passing Lamps wired to high beam
  • pedrod59
    pedrod59
    2010 FLSTF
    I had passing lamps fitted to my Fatboy when I bought it.
    They were wired to come on with Lo Beam.
    I have now upgraded from 35watts to 55watts
    I have 2 Questions:
    1/     I want to change the passing lamps to come on with Hi Beam now.
    How do I do it? Is there a simple way to change over, ( that is, remove the Lo Beam feed and connect to the Hi  Beam feed.) Where do I find this feed?
    Anyone got photos? Diagrams??
    2nd Question:    Now that I  am using 55 watts per light, should I have a relay? (not sure if there was one fitted). Would a relay be of any benefit)
    Has anyone ever done this to their bike?
    Any suggestions or help would be appreciated
    Thanks
  • Hoodaman
    Hoodaman
    Interesting question.I would like to know that as well.
  • AJ56
    AJ56
    There was a post about changing the config wiring to come on on High beam. As far as the relay goes. I don't think you will need one. This was answered in your previous post on this.
    http://www1.hdtalking.com/tn634s3.jpg
  • rider
    rider
    By law you've gotta have driving lights switched, and only able to come on with high beam,,,,
    So your best option is to re-wire them through a reley that is switched from the high beam circuit.
    Basic reley wiring diagram.
  • rider
    rider
    Reckon with the 35 watt globes they get away with it by calling them "passing lights", or deem them as daylight running lights ???
  • WozzA
    WozzA
    Just splice your low beam feed into the High Beam feed in the switch block...
    I cant remember if you splice the YELLOW into the BLUE...?
    or BLUE into the YELLOW...   this way you have Passing lights working on BOTH Hi & low... & retain the on off switch..
  • pedrod59
    pedrod59
    Just where is all this wiring on the bike. Where would the dealer have spiced into the Lo-beam circuit.......under the tank, under the seat.?????????
    If it is under the tank, how do you remove the tank?
    I wouldn't mind adding a relay as some people have suggested, but where would be the best place to fit it. I thought  the dealer would have spliced into the Lo-beam circuit in the headlight bucket, but nothing there.
    What are the colour codes for the headlights?
    I want to wire into the high-beam circuit only. I got in the shit one night when I was driving my car with the fog lights on. Police pulled me up, lucky he was in a good mood as he would have booked me. Apparently it is illegal to drive in Qld with fog lights on unless it is foggy.
  • WozzA
    WozzA
    in the Hi / Low switch block on ya handle bars...  I did mine years ago
    as I said I'm unsure which one into which one / colour without  going out pulling mine apart to check them out...
    have a look into at a wireing diagram..  or look on here tomorrow night & I'll check..
  • WozzA
    WozzA
    it works on BOTH beams.... not High ONLY...
