Online: John.R
Riser extensions for Fat Bob and Wide Glide 08-11
  • Gilbo
    Gilbo
    I'm in the process of making 2 inch riser extensions for my FXDF, as I've found it very hard to find longer risers to suit 1 1/4 inch bars. I've sourced the materials, organised my powder coater and done all the measuring and research to get it right. While I make mine, I thought I would see if there is any interest from other forum members wanting the same thing. I'd be more than happy to knock out extra sets or even make them to order if there is enough interest. Should I sell (cost price plus postage to members) the extensions as a stand alone item or in kit form (bolts included)? I could make varying lengths, 1", 1 1/2", 2". The only issue that I'm aware of is with 2011 models having a slightly shorter clutch cable than previous years but not a hard issue to get around. Any thoughts, queries or questions?
  • Gilbo
    Gilbo
    Wouldn't be hard Piglet, I'd just need the measurements (external diameter, internal bore size for the bolts etc) and whether you want powdercoat black, polished or raw?
  • Gilbo
    Gilbo
    PM your size, finish and a photo of your setup so I know what I'm lookin at ;)
  • Gilbo
    Gilbo
    Thanks Phil, that's where I got the idea. 1" will work on 2011 models or 2" if you nab an 08-10 clutch cable which is what I've sorted for mine. Apparently the only reason HD shortened the cable was to tidy it up a bit.
    Personally I prefer the black straight up risers and as I have long arms and legs this is an ideal mod for me, just thought I could punch out a couple of extra sets when I do mine if forum members wanted them.
  • xcited
    xcited
     Gilbo mate I would be keen for a set of Black 2" risers with bolts... How much you want? PM me if you like.
  • shamus
    shamus
    hey blokes just wondering wether anyone on the forum would be interested in buying a near new set of genuine 09 fatbob handle bars and black tribal mirrors?
  • Gilbo
    Gilbo
    I'll sit down and work out my full costings when I get home (away with wifey for the weekend) but I'd expect around the $15 -$20 mark dependent on what bolts I can source, plated or stainless etc
  • Gilbo
    Gilbo
    Sent two sets of to the powder coaters today and should be back by mid next week. I will be using 2" over stainless bolts and all up should cost no more than $30 posted per set. PM me your details Xcited if your still interested and I'll get a set off to you next week ;)
  • xcited
    xcited
    PM sent.
    Thanks again Gilbo mate.
  • that big fella
    that big fella
    hi , is it too late to add an order ? i want to lift my fat bars up a bit , about 2'' or so , i got heaps of cable . ?
  • Gilbo
    Gilbo
    What risers are you using big fella? If they are not the same as stock FXDF I'll need some measurements ;)
  • that big fella
    that big fella
    well , i just had a good look and there are extensions on it already , they are 38mm high by 28mm wide.. so i might ditch the t-bars and put a set of 10'' pull backs like of a wide glide oe street bob ..
  • Gilbo
    Gilbo
    No worries ;)
  • DARKRIDER
    DARKRIDER
    Hey there Filthy Phil.
    just wondering if you'd measured how much further back those pull back risers place your actual hand position compared to the standard Fat Bob risers.
    I'm 5 foot 10, but reckon I'd be much more comfortable with the bars about 4 inches back to give me a more upright riding position, and also to shift more weight to the rear for better handling.
    Cheers over a coupla beers
