Its Finished (part 2) or is it?
  • terroristone
    terroristone
    looks good mate, except for the wiring below the tank! what happened there? Rats?
  • one_oak
    one_oak
     looking good man, how do you find the rsd filter? Was there much power difference going from heavy breather to rsd one?
  • one_oak
    one_oak
     yeah i really like the RSD style filters, just worried about oil leaking
  • watto883
    watto883
    LOOKS GREAT MATE .... shame about the weather today ...... got a mate coming over to resolder the wires to my mirrors ... just sprayed them black ... came up ok ( for a chef )
  • 48fan
    48fan
    nice one
  • terroristone
    terroristone
    Hey Scouser, use this stuff http://www.larpro.com.au/larpro/category/124 it will give you a neat finish and protect the wires from the weather/heat. you can usually get some for free from good auto elecs, if they try to give you that ribbed split plastic crap don't take it. It will give you a nice clean/neat finish and will allow you to piss off that first bit of plastic cover near your seat.
    Regards Andrew.
