Online: Ronmac
just adding andrews cams
  • simmac18
    simmac18
    Hi guys my search for things goes on has anyone just done an upgrade with Andrews cams either 26 or 37, chain driven to a softail or fatboy and a super tune?  What was the result, what sort of power, any good for 2 up etc?  I am looking to make some changes to my bike and I have been looking at a 95 upgrade but the more I read , so if I was going that way I was thinking of cams and a tune while I get the cash together.  Any help would be great, I have been quoted anywhere from $2200-$2800 for the 95.
  • simmac18
    simmac18
    Yes, the only thing they have said is if they find something else messed up inside that may need replacing they also gave me a price on doing some head work not sure what though for about $1300.  I was wondering though if I should look at trying the cams and a tune first.
  • simmac18
    simmac18
    Thanks Hogbagger, just had a look at his site where abouts is he?  You've obviously used him before, pretty good is he
  • 2005 FLSTFI
    2005 FLSTFI
    running 95", Andrews 37's, fatcat, with stock heads & TTS ATM & it really does pull hard.
    going up to 98", Woods 6 & Stage 3 heads very shortly.
    I am still debating whether to leave the 37 in just to see what its like with the 98", then swap out to the 6 & decide which 1 gets me the best enjoyment
  • simmac18
    simmac18
    Thanks Hilly, I think I might try the cams and tune first then add the others later if I'm still not happy, it might cost a few hundred extra that way but I'll know if I like the cams or not, while I try to find someone else who's done the same with 26's.  The more I look into it and read about the 37's they look pretty good, what sort of HP and Torque do you know?
  • simmac18
    simmac18
    The 37's are sounding better and better to me 2005 FLSTFI
  • 2005 FLSTFI
    2005 FLSTFI
    Simmac
    With the parts I had on mine the numbers were 81 HP, 96 TQ
