Online: Bullshark001
BRAIDED LINES
  • percy
    percy
    IM THINKING ABOUT PUTING BRAIDED LINES ON MY DELUXE ,   I KNOW THEY LOOK A LOT BETTER THAN STANDERED LINES BUT DO THEY WORK A LOT BETTER  , AND IS IT EXPENSIVE TO  GET ALL MY LINES CHANGED TO BRAIDED ONES BY A PROFESSIONAL ?  CHEERS.....
  • AJ56
    AJ56
    Mate they work just as well as the OEM ones. Tip don't go cheap (Motionpro) I had a clutch cable go on me ( bottom seal) and the throttle cable adjusters rust. Diamondback cables from Harley are good as well as Barnetts. Give Luke a shot at HH and see what price he can get them for you. I know I paid a heap for the clutch cable. All the SS cables are differing is lustre so try to match them as sets. The Harley cable is a lot brighter then the others I have. One day I will swap them out for Daimondbacks.
  • AJ56
    AJ56
    Also do it yourself, it is not that hard. apart from the front brake swap. But thee is a sticky on changing and bleeding front brakes in this forum. The money you will pay for someone to put them on will probably pay for a clutch cable, or throttle cables..... And you have the added benefit and satisfaction of working on your own bike and seeing the end result.
  • Chaser
    Chaser
    Talk to the guys at Burleigh Bars.  They have all of the correct cables at cheaper than HD prices.  I've got them and they are excellent.
    got an excellent price off Luke for the Diamond-Black Collection from HD... only $20 more than a landed price from the US
  • percy
    percy
    thanks  fellas ..
  • Magilla
    Magilla
    All Diamondback cables and hoses arrived today from the US (M&M) for the Fatty.
    Clutch cable $83.22
    Front brake upper and lower hoses $99.80
    Rear brake hose $83.44
    Throttle/idle cables $116.63
    Total $383.09US convert to Aus $ at about $1.08
    About $400 with freight all up
  • Train
    Train
    Talk to Walka at VPW ....He'll be able to help you out.
    Also Magnum Shielding in the states is another option
  • lordoss
    lordoss
    Most braid cover kits are only for show. They don't actually provide any increase in braking ability.
  • the_mongrel
    the_mongrel
    They increase the breaking affect by not ballooning out.
    "The stainless wire braid more effectively resists expansion due to pressure inside the hose core. This in effect improves brake system effectiveness by more directly transferring operator input to brake friction surfaces"
  • the_mongrel
    the_mongrel
    oops!! My bad!! <img src=" border="0" src="/DesktopModules/NTForums/themes/_default/emoticons/sad.gif" />
    Sounds interesting... any links?
  • the_mongrel
    the_mongrel
    Ahh!! I know this stuff well. I used it on my V-Star. It is not bad... BUT... you need to be able to secure each end and pull it tight. It frays at the ends, so you need some way to tidy it up. What I did was to use black Heat Shrink to shrink over the ends to tidy it.
    It looks OK... but does it look great - No.
  • the_mongrel
    the_mongrel
    Yeah no probs. I just looked my entire photo library to see if I could find a pic. But I don't seem to have one. I will keep looking though.
  • the_mongrel
    the_mongrel
    Yeah cool. I am interested to see what you think.
