Online: softfat
Flush mount LED fuel gauge and filler
  • mickle
    mickle
    Has anyone had trouble with these, i have heard after a while the LEDs stop working. I am thinking of fitting these to my 2011 Fatboy but if the LEDs are unreliable is it worth the hassle.
    Cheers Mickle.
  • JD
    JD
    i like mine but Phantoms right the fuel cap does sit a mm above but I never had a peel problem
  • toxic
    toxic
    while I don't have the flush mount filler, I have the flame version with the LED's....so far no problems with the lights...... they should outlast the bike ......
  • mickle
    mickle
    Thanks guys for the feedback, currently waiting for a quote from Luke at
    Harley Heaven for the black gloss, i think they will look good with the black
    Fatboy tank.
  • JD
    JD
    didnt have the black when i got mine but think they look good
  • mickle
    mickle
    Got the quote back from Luke at HH for the black gloss $210 inc GST wich is a great price as they are $199 in America,ordered today.
  • JD
    JD
    great price
  • the_mongrel
    the_mongrel
    If your cap sits high... sand the bottom of it! Mine sat proud and after some slight sanding of the pastic - sits perfect!
  • mickle
    mickle
    Thanks Mongrel
    I hope it wont sit high as i am getting it fitted by Harley Heaven whilst its in for a few other mods.
    Cheers Mickle.
  • the_mongrel
    the_mongrel
     Yep, it should work with all of them.
    We had one sent wrong - they sent some other model that had a really long bit on the inside of the cap.  A dremel and some sandpaper fixed it!!
  • Taffymarsden
    Taffymarsden
     Mine fits fine and have had no probs with the chrome (it's 7 years old). One of the LEDs went out a month ago but after a few days came back on and hasn't had a problem since.
    The one problem I had recently was the cap wouldn't pop up so I couldn't get the cap off. After fiddling about with it for ages I finally managed to get it of and found that the pop-up mechanism had gotten very stiff. I fed a bit if light machine oil into it and it's working again but I expect I'll need a new one eventually because you blokes are going to give me a very hard time when we pull in to fuel up and I can't get the cap off!
    I think they look great.
