primary oil leak
  • beerman
    beerman
    how is everybody, ive got a 2007 superglide with forward controls,  the cap that replaced the selector shaft has developed a leak, any ideas on what to reseal it with
  • taki31
    taki31
    take primary of mate should be a seal on the in side get it replaced
  • beerman
    beerman
    Thanks very much.  Is there anyway of gettin the cap out without removin primary cover. If not id better order a gasket.
  • Stewy
    Stewy
    There should not be any oil behind the plug.
    There is a gasket inbetween the outer and inner primary cases.
    When foward controls have been fitted and the old shift sharft is removed .there is nothing to stop the covers fretting and the gasket becomes lose and leaks.
    Have a look at the other end of the hole you will see oil there to.
    To repair-  Remove outer primary replace gasket. Remove chrome cap while primary is of. Refit primary cover
    Insert dummy shaft ie neat fit wooden dowell into old shift shaft hole to stop cases fretting.replace chrome cap
    My 07 streetbob leaked within 1000ks of fitting foward controls, did the job hasnt leaked since. Done 30000ks
  • Stewy
    Stewy
    Have a look at uncle ho,s link.
    No 4 Tower gasket, is the gasket that needs to be replaced.
  • Noodle
    Noodle
    Hmmmm.... Anyone interested in my new business venture.. exporting Australian 5 cent pieces to the US... (Aftermarket)
    1. 5 cents
    2. Mark up 20 cents (profit)
    3. Shipping charges ($30)
    Total cost of product: $30.25
