Online: John.R
Error message
  • Frank7214
    Frank7214
    Went to kick the Rocker over last night, but guess what, flat battery, was going to go to Harrys to meet up with Rick. Bought a trickle charger, disconnected battery and fitted, charge up overnight, all good and kicked over. What I did notice was a error message  and low fuel light on. Bike is running perfect and full of fuel. Any suggestions.
  • smeemn
    smeemn
    Low voltage kicks up a lot of errors,not necessarily faults but messages reset them make sure battery is at full then start her up.
    probably kicked up by low battery as indicated... al error messages are stored in memory.
    all you need to do is access the messages and reset... think from memory this is done by holding the function button (on dyna next to speedo) and turning the ignition on... then use the function button to access the various messages and reset (vague but think you get the drift)
    see how this goes... like I said from a Dyna book
