Online: GGUser743, 78gold
Sissy Bar Height.
  • FrankW
    FrankW
    Before I go to My local dealer tomorrow I thought I would ask the question on here.
    When I bought my 2010 Super Glide it came with a Medium Low Sissy Bar Part No. 52754-04
    After a ride yesterday, her who must be obeyed said she wants a taller Sissy Bar.
    I looked in the Harley catalogue and found a Low Sissy Bar Part No. 52735-85 which is supposed to be taller than the Medium low one.
    Does anybody know how much taller?
    Or if they have the Low one, how tall is it overall.  Then I can compare it to the height to mine.
  • FrankW
    FrankW
    Hi Steamer,  With the touring seat there is a gap of about 3 inches with the Medium Low rest.
    My wife wants a taller one so that the pad is higher up her back instead of pressing into her pelvis.
    That's why I was looking at the Low one.
    I looked in the catalogue and the Tall one looks too tall.
    The Short one sits very low.
    It's a bit confusing when they describe them as Short, Medium Low, Low & Tall, then don't tell you the difference in height.
    I am going to the dealer today to see if they know.
    I will let you know what answer I get.
  • FrankW
    FrankW
    No problem Stephen.
    Going to take the Medium Low (I think it is anyway) to my dealer later today. So we can compare.
    I will let you know what we decide on.
    Send me your email to frankandjoanna@hotmail.com and I will send you the pic of mine as it is now.
  • yelladawg
    yelladawg
    Gidday i had the same problem. I changed suspension to ohlins front and rear and now smooth as. Get the occasional jolt when hit a bridge or bump over 120klm. But smoothed it out. Missus so happy even changed med low to low gave bike better looking lines.
  • FrankW
    FrankW
    To anybody thinking about the sissy bar heights.
    The LOW is 70mm higher than the MEDIUM LOW.
