SILENCER GRIPS AND PEGS
  • 666
    666
     Has anyone used these grips or pegs and what where they like good or bad?
  • thereyougo
    thereyougo
    Same, I'm looking at fitting the Silencer shift peg as I already have the Silencer shift rod linkage which looks dam fine.
    Does it function well or is it just a pain in your left foot?
  • thereyougo
    thereyougo
    Does it whistle in the wind, play a tune perhaps?
  • thereyougo
    thereyougo
    Thanks heaps Kato, your a wealth of information, they do look shit hot but I didn't know about their functionality. So unless you get leather crocodile skin on your palms these grips will act like a cheese grater and not much chop for pegs as they can be slippery when wet. Thanks again Kato, might look at diamond cut shifter peg for a bit more grip.
  • Kato
    Kato
    with gloves on (and who rides without gloves) there is no cheesegrater aspect to it .
    Just not as comfortable as rubber type grips ...........but the Silencer grips do look the goods
    happy to assist
