Online: tussuck
09 RoadKing dynoed
  • CraigAdel
    CraigAdel
    Hi
    Have a 09 Road King - had SE 204 cams , quick install Pushrods, Monster Ovals, HD EFI Super Tuner and Mach 5 air cleaner  installed and cat removed  yesterday - dynoed today at HHeaven.  Max Power 86hp Torque 97  - how do those figures sound? Just curious to compare to other baggers
  • watto883
    watto883
    well mate i think those figures are AWESOME !!!!
  • cruser
    cruser
    Where did you get the cat removal done? Looking at getting the cat removed from my 2010 Ultra Limited, it is a bit hard to justify the cost of a new set of headers.
  • kaboom
    kaboom
    sounds good what do you mean by cat removed
  • CraigAdel
    CraigAdel
    Had the catalytic converter removed - job was done by a mate who rides with me in the SA HOG group - he told me it will give an extra 5 hp and also the right hand exhaust is now much cooler cause thats where the cat was located.
  • obie1
    obie1
    My 09 streetglide with stage 2 103 kit makes about 80hp and 95 ft/lbs of torque. Its ok but any suggestions on cost effective hp per dollars spent improvement much appreciated. it has the standard se255 cams and se mufflers along with se billett ac.
  • UltraBaggy
    UltraBaggy
     G'day Craigadel
    I have the same mods as you have done except I have a SE stage 1 A/C.
    My dyno was 89.22 HP
                             94.14 TQ
    Bike goes great and still good on fuel
    09 ultra
  • V2Evo96
    V2Evo96
    CraigAdel-- Please tell us at what RPM the torque curve was useful (building and dropping).
    I'm thinking about the SE 204 cams versus the Andrews 48H. Your info would be valuable. Those are good numbers for your modifications by the way.
  • CraigAdel
    CraigAdel
    Torque curve starts at 80 at 2400rpm rises to peak at 97.24 at 4000revs drops gently to 88 at 5000revs to 82 at 5500revs to 72 at 6250 revs where the dyno stops.
    Is that what u wanted??
    Regards Craig
    PS Basically this means that from 2750 revs to just under 5000 revs the torque is at or above 90 - which is in the rev range that I ride and suits the bike/motor - so I deduce from that  that the SE 204 cams are a good choice for this bike and how I ride.
  • V2Evo96
    V2Evo96
    Yeah that's good info-- much appreciated! Those 204's may be coming on a little late for a heavy Ultra but I can see where they suit a RK just fine.
