VTune program issue
  • AJ56
    AJ56
    Try re- installing the program completely. ( Any maps that you have made put them in another folder before reinstall. Bit of a stuff around but it might fix the issue. You might have a corrupted registry key that is causing the issue.
  • Steve Cole
    Steve Cole
    Are you running anti-virus software? If so shut it off and see if it resolves the issue.
  • Yositime
    Yositime
    Perhaps try loading the TTS driver?
  • Steve Cole
    Steve Cole
    Some various anti-virus programs do not care much for encrypted files. IF you happen to hit the wrong combination things come to a stop quickly.
  • Humbug
    Humbug
    done my head in reading this lol
  • Frank7214
    Frank7214
    You need another numb nuts ride.
  • Steve Cole
    Steve Cole
    Vtune requires the .net enviroment to be installed on the PC. It is included on the TTS CD. It could be you do not have it in place. I would uninstall Vtune then make sure you have the .net in place before reinstalling.
