Online: Stuart
Shotgun Shocks
  • Tuddy
    Tuddy
    Purchased new shotguns for my heritage couple of months ago from hd bits best thing ive ever bought
  • percy
    percy
    POST SOME PICTURES IF YOU CAN..... THANKS
  • Frnkstn
    Frnkstn
    Just whacked the Shotgun shocks on me FXST..... FANTASIC. What a difference.... Anyone considering this move should do it..NOW...!
    I was very disapointed the stock shocks.... So much so that I used to dread going on a decent ride.
    I used to take me old 1983 GS1100 Suzuki instead.... BUT NOW.....  I can't get off the Harley...... A HUGE improvement.
  • Frnkstn
    Frnkstn
    No probs Robo. The hardest part is undoing the rear shock bolts that have had threadlocker on em.
  • Frnkstn
    Frnkstn
    Shocks straight bolt on. Tap only needed to install compressor on .... I think 2002 and earlier.... I THINK!
    We installed a mates set of Shotties,... 3 hrs and a slab of cans. He has a 2008 FXST and no need to tap.
    http://www.hdforums.com/forum/air-suspensions/566218-the-official-shotgun-shock-review-install-thread.html
  • FatboyMick
    FatboyMick
    How much where you're Shocks Tuddy? I gotta get something under my Fatty, these standard shocks are rooted.
