Online: Ronmac
Passing Lamp Bulb Upgrade
  • pedrod59
    pedrod59
    Hi,
    I have a 2010 Fatboy with passing lamps fitted.
    It currently runs H3 35 watt halogens bulbs in the passing lamps. I want to upgrade to  brighter 55 watt bulbs.
    The question is; will my electrical system run this extra load?
    I am not sure what the output of the electrical system is. Would I be overloading the charging system?
    I am still running the standard headlight,  H4 60/55 W. I will be changing the halogen headight bulb to a brighter H4 60/55 bulb ( Phillips X-Treme Vision) very soon, too.
    Thankyou
  • rider
    rider
    Charging system will be more than covered.
    I'm prety sure the 2010 twin cams run a 38 amp alternator now.  and a 40 amp main fuse.
    At 12 volt X 38 amp = 456 watts
    At 13 volt X 38 amp = 494 watts
    High beam          60 watts
    Passing lights  110 watts
    tail light                   5 watts
    stop light              21 watts
    turn signals         42 watts
    ECM/fuel pump   20 watts
    Total =                 258 watts = 21.5 amps
    ( leaves 198 watts/16.5 amps to spare at 12 volts, a little more at 13 volts)
  • als1200
    als1200
    gday, with your h4 phillips have just released the new plus 100, i havnt tried them yet (we only got stock this week) but i am running at present the crystal vision (very good). never tried the plus 80 but my rep did in the company car and didnt like them.
  • pedrod59
    pedrod59
    Are you running a relay with the passing lamps?
  • rumman
    rumman
    i have been running 55watt globes in the passing lamps on my heritage for 18months with no dramas.
