Online: beaglebasher
Tips on buying a 2nd hand used Sportster
  • lee2
    lee2
    Hi,
    re: Tips on buying a 2nd hand used Sportster
    I am a student and looking to buy a 2nd hand used Sportster.
    It is a 1986 model and has been tinkered with.
    If there is anything I need to or be weary of when buying used Harleys?
    I started it up cold and it started fine and blew no black/blue smoke. Anything else I should look into?
    Really don't want to buy a lemon - any help would be appreciated.
    The modifications it has had include:
    XLH883 with 1000cc Big Bore Kit
    Screaming Eagle Cam
    CV Carb
    Softail Springer Front end
    Fat Bob Tank with tank mounted dash and speedo
    Bobbed rear guard with cats eye taillight
    Chromed rear swingarm
    Chromed oil Tank
    Slash cut turbo exhaust
    19" Front Wheel
    10" Rear Shocks
  • Warblade
    Warblade
    all lights work? tyres ok? scratches or dings in metal work that might show its been dropped? vibration at any speed? brakes dont pulse when applied? everything in the dash/speedo work? cant think of anything else atm........
  • lee2
    lee2
    Hi,
    Thanks for the replies.
    I am in Adelaide. Do you know of anyone that does motorbike checks?
    The RAA in Adelaide do very thorough car checks but they do not touch motorbikes.
    The bike is a 1986 Sportster and he wanted $6500 but I haggled it down to $5000 which seems like a bargain; but don't really want to waste my student savings on some metal.
  • lee2
    lee2
    Hi,
  • Aussie Dave
    Aussie Dave
    Try bike works
    Is it the one on gumtree?
    Theres a 82 aswell that has alot of new parts.
