Howdy All,
Getting some new tyres put on the Muscle soon so thought would take the opportunity to powdercoat the wheels at same time.
Ok the deal is they have to be sandblasted first then powder coated.
Thinking of doing the swingarm also.
Anyone out there done it ?
Did you take bearings out of wheels ?
What do I need to be careful with etc ?
Same as everyone else on here I'm sick of the water spots/polishing etc...
Cheers,
Leave the bearings in while being blasted then remove afterwards,That way the bearing surfaces are protected.
Don't rely on the blaster to tape up cos the bloke in the office that takes your job usually isn't the blaster.
Wear gloves to prevent natural oil from your skin contaminating the blasted parts.
Point out the areas that need to be masked to the powder coater & check that it is understood.
As with the blaster,the person taking the job may not be the one doing the spraying.
When a bearing is removed it is always recommended to replace with new.
At the end of the day however it is your coin.
