86 sporty misfire?at low rpm?
  • Mitch75
    Mitch75
    hi all,i have a '86 883/1200 she was running fine but has just developed a major issue with misfire? at low rpm.Fine when ya gunning her just problem when ya coasting and low revs,so i cleaned out carby (checked for obstructions in both jets)checked for vac leaks,checked all electrical connections and plugs,not sure what to check next?any ideas?mitch.
  • als1200
    als1200
    have you changed the plugs and leads? were these a points model?
  • kevlad
    kevlad
    mine does same thing only thing i have not done is the plug leads
  • Mitch75
    Mitch75
    new 'screamin eagle' leads and 'hd' plugs not sure about 'points model'?gonna try swapping coil and ignition module over for old one's that were working!hopefully that may be the problem otherwise i'm stumped?!
  • als1200
    als1200
    yeah, if you have an ignition module then its either been converted to electronic or it came std with electronic. i reckon your on the right track. what about the enricher.....make sure that is pushed all the way back. mine will give a backfire only when its cold, and i found that it only likes 95ron fuel....just reminds me your not running vmax fuel are you. daughters quad ran really crap with this high quallity fuel...changed it over and was fine.
  • Mitch75
    Mitch75
    well after some stuffing around it seems to be the ignition module and a loose connection!
    typical mount gambier weather road testing in sideways rain yeah!
    thanks for your input 'als1200' i didn't even think of the higher octane fuel being a problem(just beeen using premo from mobil)
    'banfrogs' 'ya pointed me in the right direction again mate,bloody GOLD,cheers mitch.
