Online: John.R
pan cruise help
  • Gnoo
    Gnoo
    Hi guys, anyone had experiance with these.
    Have just fitted pan cruise compressor shocks.
    Pumped them up to suggested preasure(1.5 bar) but they leak down almost straight away .
    Valves are tight and not leaking.
    Pissed......you bet ya sweet ass I'm pissed.
  • Gnoo
    Gnoo
    HB, it's not the air line end it's the pump up end(other end)
  • Gnoo
    Gnoo
    Yer, rebuildable,but be'n new I'm thinkin warranty ? although startin to think it could be a faulty pump i'm use'n  (also new)
    In the fullness of time all will be cleard up no doubt.
  • Gnoo
    Gnoo
    Why are people so unkind
  • Gnoo
    Gnoo
    HB  Thanks for ya effort m8.
    IMOO  had to buy OS ($2,000 cheaper) just could not afford to buy local
    Today I tried a push bike pump and tyre gauge, I''think'' they are holding
    Will send suspect pump with gauge back to seller tomorrow.
    Thanks for link.
  • Gnoo
    Gnoo
    Just got answer from fournales.(france)
    ''Sorry but that is not possible
    Ideal pressure is 1Kgs. However is not possible to check pressure,too small volume.''
    So there ya go. Interesting that 1Kgs(.9804 bar) is only about 40% of pressure quoted ( 2.5 bar) in issue 107 heavy duty mag
    Same bike same shocks;;;;;;;;;;;;;;;; go figure.
    Just have to play around with the pressure a bit and suit me self.
    Seems pump WAS the problem.
