Cheapest tyres/fitting in Sydney??
  • Bandit2011
    Bandit2011
    Hi All,
    New to forum, ride a 2010 Fat Bob. Looking for the cheapest place to get tyres fitted in Sydney. Local HD dealers charging over $300 for rear hoop and labour. Is this excessive? Hoping there's a better deal around...
    Cheers.
  • 99Dyna
    99Dyna
    Try MCA, if you supply them just the rim, they will fit the tyre, you will have to take the wheel off and on the bike. $300 sound about right though, i had my dyna in getting work done and got mild to wild to change that back tyre while it was there and he charged me $310 for an avon venom fitted.
  • MUZZ101
    MUZZ101
    Try C & R engineering at Revesby.
    I saved heaps on my white walls from them.
    Cheers..Muzz101
  • Rick1310
    Rick1310
    You carn't go past MCA Auburn
