Online: Hilly, Rextheute2022
240 phat arse kits
  • Aj74
    Aj74
    Hi there people I am new to this site so take it easy on me. I have a 2000 model fat boy in bronze pearl colour very similar to commodore gold It has big bore kit cams rev box thunder slide kit and a set of Vance & hines big radius pies and am now wanting to fit a 240 phat arse kit and am Hoping some one can give me info on what kit to use and what not to use the more info the beta please as I will be doing all work my self except paint
  • houli
    houli
    Just my 2cents, your money would be better spent on suspension and brake mods
  • Aj74
    Aj74
    Sorry mate I forgot to mention I already have progressive springs in the front with 1.5 in longer legs and furnallies in the rear. I have braided brake lines and don't have an issue with them since.
  • Frnkstn
    Frnkstn
    Need help with that stutter?
  • Aj74
    Aj74
    I fixed that stutter thanks guys
    Dicks dobbed me in again,,,,He's the best
    There is a few Kits a around, Zodiac is one of the Cheaper ones and I wouldn't use one. There made in China and not good.most of the Parts dont fit up right.
    Luke at Gworks build a Owsome 250 Swing Arm and can supply it in a Kit form with all the corect Parts for the Off Set his number is 03 5277 9296 Here is his link http://www.gworkscustomcycles.com.au/
    I can help you with the rest of the stuff, Wheels, Tyres, Frenders Seat  and Brakes at the right Price, VPW 03 8405 9212. your welcome to call if you need any more info
  • Aj74
    Aj74
    Thanks that swing arm sure looks the goods I will get in touch with him next week
  • grub22
    grub22
    G'day AJ, Ive got the same model as yours, got a question, have you ever had trouble with your bank angle sensor?
    If not can you do me a big favour?
    When your dissmantle yours for the new swing arm etc, can you have a look at the bank angle sensor "black box 2" x 1" one bolt/screw holds it onto frame next to TSM below battery in front of back tyre.
    I need to know if there is an insulator between the sensor and the frame.
    Ive had to bypass mine coz vibration causes it to shut down the ignition at 110 kmh.
    Thanx........
  • Aj74
    Aj74
    Grub I have nether had a problem with it and I have never heard of it mate and it might be some time before I do it as I am just looking for options and getting prices together but I will look in the work shop book and get back to you.
