Online: Hilly, Rextheute2022
TAB fuel tuner fiited to my NRS, Engine Check Lamp is on all the time????
  • ralphski
    ralphski
    Have just fitted TAB slip-ons ( non baffled ), K&N filter and a TAB fuel  tuner to my NRS '10. Two things i need to sort out. One, the "Engine check lamp" is on all the time, I believe that i connected it all correctly. Also, bike runs rough cruising around the 2000-3000 rpm range, and back fires when you button off? Any ideas would be helpfull, i haven't started to change the settings as yet, unsure which way to go?  Midrange and top end, i'm happy with, Nice note and pulls well.
  • watto883
    watto883
    hey ... honestly not many guys ride Vrods on here ... do you use 1130cc.com ??? post on there and you have it sorted in 10 mins flat ... Cheers Paul
  • ralphski
    ralphski
    I'll try 1130cc.com, i've not heard of this site. thanks for the info. Maybe catch up for a ride sometime? Any other guys ride rods in Adelaide?
