Online: tussuck
Electrial Help
  • Rick1310
    Rick1310
    Hi All
    I need help, riding home today I lost my speedo, tacho, brake lights blinkers & horn. I have checked the fuses I will be reading the book but any help would be great. Thanks in advance.
    Rick
  • rider
    rider
    Without looking at a wiring diagram, it sounds first up that a wire from the ignition switch/on terminal  that supplies Instruments , horn, blinkers and brake light has come loose or come off.
    Maybe a quick check at the back of the ign switch terminals.
    My guess is that seeing as the donk still ran, there is still power at the Ign/on terminal and the ign switch itself is OK.
  • Rick1310
    Rick1310
    To get to the switch I will have to lewave until the weekend not enough hours after work to do this sort of job. Will just have to take the wifes car until I fix or get it fixed.
  • als1200
    als1200
    nearly sounds just like a main instrument harness plug has come apart? make sure the acc wire as mentioned earlier has not come off or blown the acc fuse? did you still have head light? i always get told to look at the last thing that you touched or put on the bike. hope you find it easy.
  • Rick1310
    Rick1310
    Well the problem has been solved the harness that goes to the rear lights had come away from the guard & rubbed against the tyre witch broke some of the wires. Of course they is not one in Australia order now & wait until the 1/7/11 for it to arrive a cost of $36 or you can just go down to Jay Car brought a few bits & piece patched up the wires re ran harnes & not a chances of it rubbing against the tyre again. Also thanking for the helpfut hits of what to look for for all. Hogbagger thanks for all the codes
