Online: DIVOT
1200 Conversion Complete
  • outbak
    outbak
    Just got my 07 XLC back today after getting the SE 883-1200 conversion done along with SE .551 cams, 10.5:1 pistons and SE Racetuner.  As soon as i left the dealer i could tell there was a huge difference. Now to run it in all over again...    Thanks for the advice KC, i should have done it ages ago.
    OUTBAK
  • LOFTYBOB
    LOFTYBOB
    Another happy horsepower junky. Congratulations & enjoy.
  • kingchops
    kingchops
    Well done outback!
    You'll be glad you did it, I've never looked back. It's a whole new bike, much more fun to ride as a 1200. I didn't know you could get 10.5:1 compression with the SE kit, did you do anything special there or is that out of the box?
  • outbak
    outbak
    I had to order the 10.5:1 pistons separately and as a result i still have the stock 1200 ones that came with the conversion kit.....so if anyone out there wants a cheap pair of standard 1200 pistons please let me know.
  • dav66h
    dav66h
    Hi outbak glad to hear your conversion worked out ok just wanted to ask did you have a fuel computer on your bike before this cheers
  • outbak
    outbak
    no.. i got the racetuner fitted as part of my conversion..
  • grafpak
    grafpak
    hi outback ,i'm just looking at doing almost the same conversion u have just done..my plan-s/e 1200 kit+10-1 pistons+pc111
    and i'll add s/e 536 cams latter on..so how is your bike running now?did you get a dyno figure for hp/tq ?and what did the whole job end up costing you ??..cheers..dc..
  • outbak
    outbak
    Grafpak,
    Due to work and personal commitments i have only done about 250km on it so far.   One thing i immediately noticed is it pops and crackles quite a bit for about 5km or so until it has warmed up, then seems to be fine.
    It cost me about 2000 in parts and about 1000 in labour. I got the parts directly from Chicago Harley in the US and had the work done at the local dealership here which costs an arm and a leg.  But i was lucky i decided on that as my ECU died after the racetuner was fitted.  Apparently the SE racetuner can only ever be tuned to a one ECU, so if your ECU dies, you also will need to replace the racetuner.  I got another ECU and racetuner under warranty...  Not sure if the ECU just died on its own or if they screwed up.  But it didnt cost me any extra so its all the same to me anyway..  I decided to get the SE cams and pistons all at once, that way i dont need to get the top end pulled down again later and figured that would save me money later on.
    Havent had it on a dyno, I dont even know if we have a dyno out here..  we have a few performance shops in town so i guess we do   If not, the closest one is probably in Darwin or Adelaide :(
    OUTBAK
  • grafpak
    grafpak
    i was going to order my stuff thru chicago harley too..let us no when u have clocked up some more k's how it really goes?
    just an opinion here but i'd be looking for a dynotuner to set up the racetuner the standard maps are very basic..cheers..dc..
  • grafpak
    grafpak
    any updates???
  • outbak
    outbak
    Bike goes real nice with less vibration at higher speeds now.  As an 883 it was a bit hairy at speeds over 130 kph.  Got it up to 160 the other day with my missus on the back and it still had more.  I am more than happy with it now.   It even sounds better..... like its balls have dropped.
  • outbak
    outbak
    The local dealership said it would not affect the warranty coz all the parts are genuine and they did all the work. Not sure how you would go with non HD parts and/or mechanic.
  • grafpak
    grafpak
    hi outback, whats your bike feel like on acceleration?
    you've done a big bore kit,higher comp,cams and the racetuner should have upped your rev limit to 7000 so it should fly!!!!!!!!!!!!!!!!!!!!!!!!!i'm not that keem on going 160 but want to get there quick!!
    also what fuel are you running? 98ron?are you getting any pinging @10.5 to 1??
    at the moment my 883 goes pretty good now so i dont want to spend 3000 without noticing a fair change!
    i raced a 96 cube bike and we were side by side to 100km' then he pulled away after 120 but he was pissed i was still beside him at 100.!!!!!!!!!!!!!!!!!!!!!!!!cheers..
  • kingchops
    kingchops
    Grafpak,
    I run stock cams and I went with the 9.5:1 compression and the difference with my bike was massive, it's a whole new bike going from the 883 to 1200 big bore. I may upgrade cams at a later date but I was very impressed with the results of my upgrade compared to the 883.
  • haynes-davidson
    haynes-davidson
    Good on ya' outbak, I'm sure you're loving every second of the ride. More power to you.
    I hope one day when I gather enough cash I can do the same. Buy more horses!!  Giddi up.!!!
    ENJOY!!!
  • outbak
    outbak
    Grafpak,
    I use normal premium which i think is 95, i have heard good and bad things about the 98 fuel. We only have one place in town that i know of with the 98 and they charge about $2 a litre for it..
    The acceleration difference was pretty huge... i really have to hang on in 2nd and 3rd when accelerating hard.
    Where the 883 used to lose acceleration at around 120kph.. i find the bike now does the same at about 140-150. I havent noticed any pinging.
    When getting all my gear together for the conversion, i was considering changing my front pulley to the 30 tooth that the 1200's use. But i dont think i need it, the bike cruises at 130-140 which is the speed limit on the open road here.. so i am happy with that. I am only kicking myself for being too tight and not getting a 1200 right from the start.
  • grafpak
    grafpak
    thanks kingchops&outback , thats what i wanted to hear!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
