overtaking mufflers
  • gaz.b
    gaz.b
    Hi , just over six weeks ago i took my 09 dyna lowrider in to be tuned,and fitted with the s&s slip ons & k&n air cleaner which i supplied .Everything was fine until out on a ride on sunday near serpentine the two mufflers shot past my right ear and on to the other side of the road .Fortuntly there was no oncoming traffic and no other damage was caused apart from mufflers which are scrached to fuck.Ive contacted  the company which done the fitting and im to bring the bike in to see what happened etc,and hope to get a new set mufflers.My question is ,is there a muffler support bracket ? i know there is a bar joining the mufflers together and a bracket supporting the header pipe but i dont recall seeing any other bracket not unless it is missing or been left off. If it does not have bracket there seems to be a lot of weight hanging from two muffler clamps .Thanks gaz.b
  • CRASHER
    CRASHER
    are there holes n the mufflers for bolts to go in...my sns mufflers do but thats for a fatty settup
