Wheel Bearing smashed
  • wildchild
    wildchild
    You wouldn't beleive it, went for a ride on weekend and got home only to find my Left Rear wheel bearing had failed.
    I wouldn't expect this to happen, really pissed about it.
    Wheels fitted by dealer when I took delivery (about 3 1/2 years ago), I am thinking maybe wrong spacer fitted and bearing finaly decided to give up! Will not know until I pull wheel of and check it.
    Riding along felt somthing wasn't right but thought it was the road surface, got home and checked rear wheel for side movement and there it was, bearing had colapsed, checked belt tension to clarify and it was looser than last time I checked. Belt tension was spot on last time I checked at about 5000klms.
     You can also see movement at axle to bearing when appling side pressure on wheel.
    Was riding 2 up with total weight of around 160kgs, shockies at factory setting.
