Online: tussuck
K&N Airfilter , Which One?
  • thebald1
    thebald1
    Hey guy's just wondering,
    K&N RK 3909  or the RK 3910 ?
     from what i can tell they will both fit the 2011 Softail deluxe ,
    The 3910 seems to flow better( thicker filter) = up to 12 Hp gain
    The 3909 is slightly thinner less flow (thinner Filter)= up to 7hp gain
    The Bike is running stage 1 filter upgrade, V&H bigshots , SEPST , at the moment
    So guess that is pretty much regarded as close to  stock,
    Any comments or recommendations on which way to go,
    Does anyone use either one of these
    Appreciate any feedback
    Cheers TB1
  • KiwiRob
    KiwiRob
    Stick with the stage 1. Ran the K&N kit on my '07 deluxe for less than 12 months. Was recommended by dealer when I bought the bike new. Disappointed with the design, as the vents dripped oil inside the filter & the rubber air stack kept falling out of it's mounting position. Poor design from a well known company.
    Replaced it with the SE stage 1 kit & put in the Zippers Maxflow filter element which is about 1/4" or so taller (PN 1011-0782). A company called Exotx makes a stainless element that should work also.
  • thebald1
    thebald1
    Hey KiwiRob,
    Thanks for the input man, will heed your advice,
    I was hoping to hear from somebody who has either used one or is using one.
    cheers mate
    Will definately look into your recommendation on filter element
    TB1
  • BURTO
    BURTO
     I fitted the Dyna equivalent model (RK-3931) on my Fatbob.
    Had a heap of trouble with bolts shearing off the stand offs thru vibration.
    If I had my time again.........I would have just bought the K&N filter to fit the standard backing plate. (at the time, I wasn't aware that K&N made a filter to suit)
    The K&N filters themselves are the ducks guts, however the rest of the hardware is not as reliable as the standard or SE set up!
    Burto.
  • thebald1
    thebald1
    Hey Guy's ,
    Thanks a heap for the info, saved me some bucks,.....Ta
    will just upgrade the element  instead,
    TB1
  • KiwiRob
    KiwiRob
    Should have said there's nothing wrong with the K&N filter elements, sorry to say their backing plate & air stack is a disappointment.
